Plus Model Suitcases
Är det någon därute som har en väska tillövers? Jag söker ett ex av den minsta väskorna i plus model satsen. Jag behöver en brevduveläda
Hör av dig till mig TACK! Pål
Re: Plus Model Suitcases
Hej Pål.
Is it one of the cases in this set?
http://www.ebay.com/itm/Plus-Model-1-35 ... 20f28fa885
If it is, I can help you with that. Is an actual suitcase or the small wicker type or I can give you one of both. Let me know and then send your postal address via PM to me.
Tänker du ha en brevduva i flygbåten? Släppte de den under flygning (schwoff!) eller när de guppade runt på Nordsjön?
Hi Frank!
Yes it is that set I had in mind. One of the smaller wicker box with a top lid will be super.
As can be seen here.http://www.iwm.org.uk/collections/item/ ... 1060022770
/Pål
/Pål
Stellan!
Helt rätt!
Som du kan se i filmlänken i mitt svar till Frank, så hade man redundans om radion inte funkade
/Pålle
Helt rätt!
/Pålle
Hej Pål
They are one piece moldings ... top lid is molded in place. They are solid pieces as well. On the other hand ... probably the best molding I have ever seen .... painted up, you would actually think it was real wicker. PM me with your address, and I will post it early next week.
