Nu tror jag att jag kan säga att jag nästan är klar, i allafall med interiören till främre vagnsdelen. Sedan skall det också göras lite interiörsdetaljer till den bakre, men det kommer senare när jag hinner.
Jag kommer att sälja denna om 1-2 månader på min "Miniature Art Productions" Facebook sida (länk nedan).
https://www.facebook.com/permalink.php? ... %2CO%2CP-R
För er som inte har FB tar jag med produktbeskrivningen här också (dock på engelska hoppas det är ok):
Bv309 / Bv206S interior - almost done now!
Well, after almost one and a half years of work (on and off) I have finally come to a stage when I can say the interior for the Bv309 is almost done (just the front/drivers section of the vehicle for now - the rear section will come later).
I have test built it with all the parts I have created so far and am pleased with the results. A few tweaks remain, but nothing major. I will also integrate the two rear wall sections into the center console to avoid the ugly seams there.
The right hand front seat comes in two versions:
1. With deployed gunner's platform
2. With folded gunner's platform
The rear (floor) radio rack is optional, and can be fitted with any equipment you like. Otherwise, just mount the left-hand-side rear seat per kit instructions if you prefer.
And yes, there will be a steering wheel with the knob as well of course!
I have airbrushed everything in light grey just to make the details more visible.
I expect I can release this set in the next 1-2 months if I can find the time to finish off the tweaks.
This is primarily to build the interior of the Swedish vehicle, but the center console and seats are just as valid for a German and other nations' vehicles. So I will also release a smaller set without all the Swedish radios.
Hoppas ni gillar den, tack för titten!
